Text Errors in PDF Publishing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2021-05-20
11:40 AM
2023-05-19
03:44 PM
Gordana Radonic
Has anyone run into a similar issue?
I'm running ArchiCAD 24.
AC 24
Windows 10
Intel Core i3-4160 3.6GHz
NVidia GeForce GTX 1660 SUPER
- Labels:
Publishing
Text
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-05-20 11:51 AM
It's not an ideal solution because turning off font subsetting does mean I end up with very large file sizes. I would really appreciate if anyone has a better solution, but here's the specific workaround for anyone having the same issue:
Affected version: ARCHICAD 11-16| Severity: workaround applicable | ID: 66304
Note: This issue was fixed in ARCHICAD 17
Issue
Text is missing from PDF files published from ARCHICAD 11 or higher on Windows.
Cause
A Font embedding problem in the PDF engine causes that certain (not widely used) font types appear white in the output file.
From Start menu choose or select Run, type regedit to open Windows Registry Editor
Find the key: HKEY_CURRENT_USER\Software\Graphisoft\ARCHICAD\<ARCHICAD version>\PDF
Double-click the DWORD entry named Font subsetting and set the value to 0.
This will change how fonts are saved into the PDF file. The result will be larger PDF files, since now all subsets of all font types will be embedded into the PDF file.
AC 24
Windows 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-05-26 03:41 PM
Thank you very much for your question! This is an interesting one!
I downloaded the given font and tried publishing a piece of sample text to PDF using Archicad 24 5000. The result is correct, there is no weird artifact in the PDF result. I'm wondering whether you can recreate this issue on a brand new default template file?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-12-07 05:51 AM
Hi James, did you ever find a solution to this issue - I have the exact same problem.
Ben
AC23-25, MacOS
Ben
ArchiCAD 23 -amp; 26
MacOS 12 - 13
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-12-15 03:30 PM
Dear Ben,
Thank you very much for the question!
Could you please let us know a bit more details about the situation you are having? Which font did you use to generate this issue? May we have some screenshots to have a better visualization of the problem?
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-23 02:05 AM
I'm having the same problem with ArchiCAD25.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-23 02:07 AM
Missing text style is Helvetica if it helps
