Text Size - Quick question
I am in the UK with AC-ST10. I use mm as my main units but I want to use point sizes for the text, is there a way of using both in the same document? Or is there a conversion chart somewhere?
Thanks in advance.
Cheers
Matt
2 REPLIES 2
Srinivas
Text size can be entered in mm/dimension units instead of points when you select the option of "Model Size" instead of "paper size".
Here is an article on how the text size in points work and the conversion chart that you are looking for.
http://www.archicadwiki.com/TechNotes/Sizing%20Text%20and%20Markers%20with%20Point%20Units
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
Thanks Srinivas, much appreciated.
Matt
