vfrontiers
Text doesn't Align
It's the little things that drive me nuts... Why does everything look fine while I'm editing, but then shifts when I'm done (and when I print)
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
3 Replies 3
Lingwisyer
Guru
Does publishing to PDF result in the same tabbing changes?
vfrontiers
Yes...
Duane
Visual Frontiers
AC3.14 - AC29
KingaW
Hi Duane,
did it start happening in a migrated file from AC25 to AC26?
I have an abbreviation list that worked fine, and it's all messed up in AC26.
I also have a tabulator set and my text is 75% in width.
If I go back line by line and make sure there are no spaces and only one tab (to the set tabulator), it works again.
BIM Manager, AC13- , now on AC27/28 USA
Dell Inspiron 27 7710 AIO@ 3.20GHz, 32 GB
Windows 11 Home, NVIDIA GeForce MX550 P2000
Florida
