Text horizontal aligned with view layout
I have a layout with a rotated viewport, now I would like to have all the text aligned with the layout horizontal, so it is easy to read. How can I do that? It is not possible to rotate the drawing by itself because of other apartments on the drawing
Thanks!
5 REPLIES 5
Erwin Edel
Hoi Marissa,
Those look like zone stamps that display text, in this case, you want to set the Zone Stamp Rotation to Relative and fix the angle to 0°.
If it is text placed with Text tool, you want to set the Text Wrapping to Always Readable.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Erwin Edel
Sadly I don't think there is a fix for the Level Dimensions.
www.leloup.nl
Thanks for your answer!
Where can I change these settings?
Erwin Edel
See below.
www.leloup.nl
Marrisa_91,
Post moved to 'Working in Archicad'.
Please look at the section descriptions to decide where best to add a post.
Thanks.
