2018-04-18
04:35 AM
2023-05-19
03:50 PM
Gordana Radonic
2019-03-15 09:11 AM
2019-03-20 03:13 AM
PrendosJoe wrote:In the case you refer to ( manufactures standard details) that can be as easy as just using an All Caps font. Lots of them out there. And you can use the Translator set up to automatically convert all texts imported to the All Caps font. If the manufactures detail is a .pdf you can display the text with an all caps font with the Adobe Acrobat Pro ( or similar version). I would think you would be able to Publish an entire set of Construction Documents as .dwg, then import them using the Translator to automatically change all text to the All Caps font.
From our perspective it's pretty basic text functionality & an additional step that really shouldn't be required, especially in a program as intelligent in other ways such as ArchiCAD. It may not take a lot of additional time, but it still does take time & unfortunately time = money in this capitalist world of ours!
Steve wrote:PrendosJoe wrote:Not a problem is it? I keep Microsoft Word open all the time just for that reason.
Thanks folks, looks like we're going to have to continue working with our current workflow. Very frustrating when you get manufacturers standard details etc and have to re-write every note in CAPS!!
Copy and Paste.
https://www.screencast.com/t/DUDHkQDdv
2019-03-20 03:26 AM
2019-03-20 05:14 PM
Paul wrote:But users are have to meet National CAD Standards with all caps.
A good possibility for those actively trying to use all caps - though less convenient for those needing to go the other way (which is most often in my case, based on the readability research and space advantages of associated with lowercase ).
Definitely agree - extended ArchiCAD functionality required to deal with this
2019-04-03 02:18 AM
2019-09-15 04:07 AM
Steve wrote:Whose national standards? Not all are the same, and some offices prohibit use of all caps, because the research shows all caps is just harder to read https://en.wikipedia.org/wiki/All_caps.
2019-09-15 06:22 PM
2019-09-15 07:36 PM
2019-09-16 04:08 AM
2019-09-16 04:22 AM
M wrote:Yes workarounds like that exist, but requires manually cutting and pasting each note, out of potentially thousands of notes
There is a website you can use to convert your text to all caps: https://convertcase.net
The spell check in ARCHICAD will check words in all caps, if you have Microsoft Office set to do so. Open Word, click Options on the very bottom left, and then click on Proofing. Make sure that “Ignore words in UPPERCASE” is unchecked. If this box is checked, the spell check will not proof any words in all caps.
