The dimension input becomes strange. I'm trying to hit 1000, but if I hit 100,000, it turns into 10
I'm trying to hit 1000, but if I hit 100,000, it turns into 10.00?
Even when editing, unexpected dots appear on backspace or del keys. Is it just me?
AC25 5010 / AC26 4019 on window 11
11 REPLIES 11
However, this kind of mistake can happen often, so please understand. If I bring a translation from translate.google.com and copy it with the translation turned on in Edge to read your answer, the translation will be translated back into Korean and saved. This is a phenomenon that occurs when I forget to turn off edge translation when saving. However, sometimes it is saved without being retranslated into Korean. ^^
Looking forward to your generous forgiveness...
It is not a problem.
You usually do a very good job at translating.
Usually we will just remove a foreign language post but I thought you should have the chance to translate it first.
I have removed it now that you have provided the translation.
Thank you.
Versions 6.5 to 26
