Transparent wall in elevation
Hi
Is it possible to create a transparent wall in elevation? I've built a shower screen with a wall tool and it has a transparent surface. But I can't figure out how to get a transparency in the section so I can see through it
Ben
6 REPLIES 6
Erwin Edel
You can turn on transparancy (for all transparant surfaces) in the Section Selection Settings under Model Display > Uncut elements > Transparancy.
Just select the section line or right click it in the project map to get to the settings.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Yes - tried that, but still showing as solid. To be more accurate this is an internal elevation tool I'm talking about, if it makes a difference.
Erwin Edel
Should work the same, make sure the transparant surface used is more than 50% transparant, or it will show as solid.
Check the Internal Engine settings. Transmittance should be 50 or higher.
www.leloup.nl
Windows 10 Pro
Bingo! It was set at 30 something.
All good now, thank you!
Erwin Edel
And now you know how to cheat your way to having transparant and 'not transparant' glass in elevation/section/internal elevation.
www.leloup.nl
Windows 10 Pro
And here is the clip that explains how this all works:
https://youtu.be/Xg-QxXzk0MU?list=PLnXY6vLUwlWWmck7MSva1egwNcIUQinFC&t=44
It talks about Composite Skins, but it applies to single-skin Structures (AKA Basic Structures) as well.
