2005-06-24
06:29 PM
2023-05-23
12:03 AM
Gordana Radonic
2005-06-24 06:32 PM
2005-06-24 07:28 PM
2005-06-24 07:32 PM
2005-06-25 01:49 PM
2005-06-25 02:20 PM
Walter wrote:
Suggestions then involved cut & paste from the 3D window, which is not an ortho view so can't be used to dimension.
2005-06-26 04:17 PM
Walter wrote:FrameWright was designed to solve this problem (and other framing issues). You can freely rotate assemblies in 3D, with the option of instantly restoring it to its true position in the model.
The only way to do this (I think) is to lay the object on it's side in plan & use the sect/el tool.
ROTx 90 does this if you want to edit every beam, save a "laid-down" version, place them around the plan, add sect/els for each.....
Like the RCP issue, it gets a bit nuts & moves away from one model.
Anyone with ideas, please?
2005-07-06 02:07 PM
The 3D Window can be set to orthogonal views. Go to Image>3D Projection Settings... and if the title bar of the dialog box says Perspective Settings, click on the Parallel Projections... button. In the Parallel Projection dialog box are 11 preset views (top down, bottom up, elevation, various axonometrics) as well as a custom option where you can set the angles of the axis and their proportional lengths. This view can be copied from the 3D Window and pasted into the plan, section, or detail window for adding dimensions and notes.Thanx 4 the tips.
