UPDATING LAYER SETS FOR A PLACED DRAWING
Hello everyone,,
I have the following problem: I placed a drawing in a layout. I then realised I need to hide a layer, that contained fills I did not want to see. I hid the layer, but, no matter how many times I update the layout, the fills still appear.https://trackeasy.fun/usps/ https://showbox.tools/
How can I solve this?
Thank you.
The drawing you have placed on the layout should be a view from the View Map.
This view will be set to use a particular layer combination.
All you need to do is update that layer combination and all views using it will update, and hence the drawings on the layouts will update as well.
Or if it just for that particular plan, create a new layer combination and apply that in the settings to the view that you have placed on the layout.
