2013-07-17
04:54 PM
2025-02-07
12:10 PM
Aruzhan Ilaikova
2013-07-17 09:22 PM
2013-07-17 09:26 PM
MarkMoscrip wrote:They recalled the 3013 patch again? today?
Works for me in AC 17. GS is recommending that you unload the 3013 hotfix for the US version. Maybe that will help. Actually, reinstall with 3002
2013-07-17 09:36 PM
2013-07-23 03:17 PM
2014-01-02 05:07 PM
2014-01-02 05:26 PM
laszlonagy wrote:This is the step that was added in 17 in all previous versions this was not needed.
3. Click on the dimension line (cursor is Mercedes shaped, meaning you found an edge, not any node) and select the Edit Length of Witness Line command of the Pet Palette.
2014-01-27 10:38 PM
2014-01-28 12:11 AM
2014-01-28 12:28 AM
ejrolon wrote:For me it used to be finicky, then persnickety. Now it's just broken. Occasionally I can get it to work if I OPTION-SHIFT click the dim line.
Take in consideration that the procedure is finicky and that might be the problem.
