Uncut lines appear in front of cut lines in sections
marian_sdraila
Hello. I can't figure out if this is a bug or is something I'm doing wrong but all the uncut lines on my section are generated on top of the cut lines and in most cases I can't even send them to back manually. I have this problem on all my projects and even on older versions of archicad. In the attached image the gray lines are uncut. Btw I'm on Archicad 23 now.
ArchiCAD 23
Windows 10
Intel(R) Xeon(R) Silver 4110 CPU @ 2.10GHz
NVIDIA Quadro P4000, 8GB - 64 GB RAM
14 REPLIES 14
marian_sdraila
That is good news! It's been a while since I remember having this problem the first time and I'm surprised that no one else reported it earlier. I kept thinking that maybe I'm doing something wrong! Thanks for the reply! Hopefully it won't take too long until it's fixed!
ArchiCAD 23
Windows 10
You don´t have to feel lonely;) We experience exactly the same issue - here two cases:
1. within the same element - a Curtain Wall (1.png)
- Cut lines of Curtain Wall = black (Graphic Overwrite).
- the uncut foreground area is only ca. 0,5 cm thick (otherwise you would see black uncut lines because of the overwrite)
- Marked Distant Area - Uniform Pen for uncut Elements = grey.
=> Grey lines appear in front of the black cut lines.
The effect is so strong that pdfs at scale 1:500 are un-readable even though the grey pen has a thickness of 0.01.
Work-around: opening in photoshop + saving as pixel picture. The pdf renderer then achieves better results
2. + 3. different elements (2+3.png)
- to achieve brighter uncut fills the uncut foreground area is only ca. 0,5 cm thick. So all uncut objects you see are located in the Marked Distant Area.
=> Curtain Wall (2.) + (3.) Objects (above ceiling) + Columns (below ceiling), all located in the Marked Distant Area, appear in front of the black cut lines of the ceiling.
This can be solved via manually "Send to Back" but it should be done automatically.
KeesW
Could it be a Renovation filter? Existing items default to grey in my AC23.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
marian_sdraila
Well, if we talk about workarounds, one would be to create two identical sections, one of them having the zero depth setting and overlaying them on the layout, the one with zero depth being on top of the other. But workarounds in general take extra time, and time is money as we all know.
ArchiCAD 23
Windows 10
The grey is intended. Black background would solve the problem but then you can’t differentiate the section lines and the background anymore.
The duplicate workaround will work. But it means two sections within the layer structure and more important it will be even more time-consuming. But hopefully not twice as much. Seems to be worth to try
