Upgrade to AC24 turns certain drawing frames a lot bigger
I have just upgraded to AC24 and noticed a few drawing frames have suddenly become huge
See below screenshots. Exact same file & same layout, one opened on AC23, one on AC24.
It's not happening to every layout just a certain few. They are set to "Manually resized frame"
Is this a bug?
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear Benjamin,
Thank you for the report, and I am very sorry about the issue!
Does it happen with any file, or with one specific file? Which language version are you using?
Unfortunately, we haven't received any similar record about this behavior. I'm wondering if you can share with us the file in AC23 for in-house testing?
Thank you very much for your help!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
I have found that it is not AC24 upgrade that is the issue but just the file that seems to be buggy. Have sent it to our local distributor for further investigation
