‎2007-02-14
11:47 PM
- last edited on
‎2023-05-30
12:29 PM
by
Rubia Torres
‎2007-02-14 11:56 PM
‎2007-02-16 07:15 PM
‎2007-02-16 07:17 PM
Dennis wrote:It's part of the Profiled Wall.
Thanks Tom - I also thought that's the only way to really get the benefit of using ArchiCAD. I was just a bit slow / lazy in digesting extra thinking (working out the design) involved in modeling w/ the actual thickness of everything. I'm thinking though, that this should help me out in wall sections / details stages tremendously.
BTW, how do you draw the X lines for the top & bottom plates in section? Is that part of the profile wall or do you draw them in manually?
‎2007-02-16 07:32 PM
TomWaltz wrote:I'm not sure what benefit you gain from this....can you please further explain your reasoning? I, personally, like to keep my overall building sections simple...this would add addtional plate lines I might not want. It's easy to add plates via an object if I'm doing a detail of a wall condition.
...With Archicad 10, we started using Profiled walls to include top and bottom plates in the walls...
‎2007-02-16 09:10 PM
Dan wrote:Because it beats placing them manually. Nothing like moving a wall then having to go back and move all your 2D plates in all your building sections...TomWaltz wrote:I'm not sure what benefit you gain from this....can you please further explain your reasoning? I, personally, like to keep my overall building sections simple...this would add addtional plate lines I might not want. It's easy to add plates via an object if I'm doing a detail of a wall condition.
Thanks,
Dan K
‎2007-02-16 09:46 PM
Dan wrote:You could use a dedicated pen for the X and use pen sets to control the visibility. Though I'm with you, I only want to see plates in large wall sections. Depends on your standards.
‎2007-03-27 10:15 PM
TomWaltz wrote:Tom, with the Profiled walls have you still been able to display the Drywall and sheathing in plan/section? can the Exterior Siding and Drywall have a separate pen so that one could give them a white pen so that they do not print for the Structural Sections, where I only want framing and Shear plywood to display?
Until Archicad 10, we used composites almost exclusively to model wood framing at its actual size with drywall, sheathing, etc.
We also have some simple walls for minor conditions where a composite is not practical.
The column tool can be used to bump out skins of the wall for a pilaster or other bump
‎2007-03-27 11:09 PM
Jay wrote:I'm not doing structural sections, but there's nothing preventing you from setting sheathing & finishes to a group of pens that print white on some drawings if you wanted.
[Tom, with the Profiled walls have you still been able to display the Drywall and sheathing in plan/section? can the Exterior Siding and Drywall have a separate pen so that one could give them a white pen so that they do not print for the Structural Sections, where I only want framing and Shear plywood to display?
