Ok, guys, I found the answer after two evenings spent on the issue.
Actually, I think this is a bug of Archicad. It seems that View doesn't correct save Cut Plane height when you changes it. In order to correct this you must:
[list=]1. Go to Floor Plan Cut Plane and change Cut Plane height to appropriate;
[list=]2. Go to the View settings:
[list=]3. Click Get Current Window's Settings
After that click OK and close View Settngs and go to the Layout with the View. The View will be corrected with correct Cut Plane height.
I want to mention that nothing will be changed in terms of combination in GENERAL settings group (of the View Settings). Only zooming option will be changed to Current Zoom.
