View to Layout issue
Hi!
Help me please with one issue. Working with this interior:
Looking at View from the top you can see correct picture:
But if you put this View to Layout, it will be incorrect:
Why this is happens? Suppose it is something with Floor Plan Cut Plane (but I changed it to the one height everywhere). How can I transfer the View to Layout without losing it's settings?
1 Reply 1
Ok, guys, I found the answer after two evenings spent on the issue.
Actually, I think this is a bug of Archicad. It seems that View doesn't correct save Cut Plane height when you changes it. In order to correct this you must: [list=]
  • 1. Go to Floor Plan Cut Plane and change Cut Plane height to appropriate;
  • [list=]
  • 2. Go to the View settings:
  • [list=]
  • 3. Click Get Current Window's Settings
  • After that click OK and close View Settngs and go to the Layout with the View. The View will be corrected with correct Cut Plane height.
    I want to mention that nothing will be changed in terms of combination in GENERAL settings group (of the View Settings). Only zooming option will be changed to Current Zoom.
