Isaac Campero
Viewer Stories
Inside of stories settings it doesnt appear the model display for apply uniform surfaces to the CUT ELEMENT in general, besides this settings still appears at the section settings and elevations.
Settings at sections settingsSettings at sections settings
I hope i will recived a succesful answer, thanks.
2 Replies 2
Yes, you are right, this 2D cut fill representation is not available for Floor Plans. What you could try and see if it acceptable for you is you could create a 3D Document from the Floor Plan Viewpoint, and in the 3D Document Settings Dialog you will have the same options for Cut Fills as in Sections.
DGSketcher
Legend
Stories work differently to elevations & sections. The general solution to control presentation in stories is to use Graphic Overrides which will do most of what you need but also allows you to have different presentations saved in your views.
