2008-02-06
03:51 AM
2023-05-26
12:07 AM
Gordana Radonic
2008-02-06 02:06 PM
2008-02-06 06:24 PM
TomWaltz wrote:However, tying the
Making the user manually tie the viewport ID to the sheet seems like extra unnecessary work to me.
2008-02-06 08:29 PM
2008-02-06 08:54 PM
jorgec wrote:James' site: On Land
Does James have some kind of description of how he does it? fom my take that method would require some additional work if the sheets ever change? Or am I missing something?
2008-02-07 02:38 AM
jorgec wrote:No - it's a one way street. Viewpoint ID> View ID> Drawing ID> Layout ID. Although at the last step, the drawing can get it's ID from it's position/order in the layout.
Is there anyway to have an option which allows the Project Map Reference ID name link back to the layouts? That way when placed on a layout, the ID will reference the sheet which it is placed and it will automatically update if a sheet number changes?
jorgec wrote:Indeed it would - and it seems like a lot of overhead to me. Viewpoints are a means to an end - we need them to create views. Maybe consider using the view map for sorting, and match it identically to the layout book. This is quite flexible, and to make it a little more friendly when signing into a teamwork project, ID the viewpoints by
2008-02-07 07:25 PM
2008-02-07 07:31 PM
2008-02-12 01:28 PM
jorgec wrote:Hi, just saw this. The key is that the IDs roughly follow the sheet number. Building elevations are A2-1, A2-2. Building sections follow starting at A2-3 or -4. Wall sections are A3-1 etc. I don't care if the number matches the exact sheet number. The goal is to have the viewpoint list generally follow the order of drawing/sheet type.
Thanks in advance
2008-02-12 05:40 PM
James wrote:Something I wish for all the time --though apparently not enough to actually post a
and who knows when we'll be able to do a proper search.
