Viewport Double Update
toman311
I don't know why ArchiCAD is doing this, but every time I open up a sheet the viewports go through the update process twice. It really takes up a lot of time too on some sheets.
Does anybody know why this is and how I can stop it?
>ArchiCAD 23, 7000 USA FULL
>iMac, 27-inch, 2020, Processor: 3.8 GHz 8-Core Intel Core i7, Memory: 64 GB 2667 MHz DDR4, Graphics: AMD Radeon Pro 5500 XT 8 GB
4 REPLIES 4
Lingwisyer
Guru
I set most of my views to manual update. Means that you need to check every view prior to publishing, but it also means that each time you make a small change, you do not get every view updating even if the change is not actually visible.
Ling.
toman311
Thanks for the reply.
I think I might miss something and create a mistake if I did that. I'd rather wait then make a mistake.
Thanks for the tip, but I don't think that would work for me.
Lingwisyer
Guru
Before publishing, you can always go to the drawing manager and update all of the internal drawings. You should not miss updating any this way.
Ling.
ahmad525
hey
was this issue fixed at all or have you found any solution ?
im having the same issue with AC25.
its annoying and makes everything slow and sometime it takes up to 1-2 minutes till you be able to do any changes or view.
