Wall Markers
Hi:
Is there any way to create wall markers such as those in windows and door so when I use my layout renovation filter I´m able to turn off all markers?
I mean beside manually drawing them
I´ve tried saving walls as doors and windows but when I place them no element appears ....
Thanks
3 REPLIES 3
Palawat
For AC20 (not sure which version you are using), you can use "Identification and Property Label 20" that allows you to select Frame Shape, disable Leader Line, etc. Being a label, it will show/hide with the wall associated.
Or, if you are one of the brave souls, I have a custom made label for you to try. It's still in beta though.
http://palawat.net/blog/palawat-symbol-label-suit-20/
Archicad 26, Windows 10, Corei7 3.4 GHz, 16 GB Ram.
https://www.indigofigs.com
https://www.facebook.com/indigofigs
Hi palawat
This brave soul will give your label a try and report any errors back. From a quick read it looks like it may work as a keynote object as well. Thank you for your generosity.
Thanks!
Going to give it a try.
Regards
