Brad Elliott
Wall cut lines in AC17
Is this a bug? In AC16 and before the Apply Structure's Settings Wall cut line used to affect the wall cut for windows and doors. I was able to change the line by changing the line in the settings even though it was turned off.
In AC17 that setting is now gone but I have a different problem. If the window or door is to the wall core and then offset I have a clean connection. If it is set to Wall Face or even Wall core but the full thickness of the wall I get the old Line 1 (Black and Thick) cut line at the wall cuts. Does anyone know how I can get rid of this in the Wall Face setting? I have attached images that show the line and the settings.
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
Brad Elliott
And here is the wall face setting. This the window on the right.
M1 Macbook Pro
