Ruben V
Wall end lines at openings (door/window) not showing
When creating a 3D document from a 3D axonometric view with 'Core Only' applied and windows and doors hidden (Filter and Cut elements in 3D), the lines of de "opening-contours" are not shown.
There are a LOT of places where this could be defined... Anyone able to help me out?
(òÓ,)_\,,/
www.studiov2.be
Archicad 26/27 + Rhino/Grasshopper
BIMcollab ZOOM
>>> Read my book!<<<
Katalin Borszeki
Hi All,
Based on a file we received, this is a known error. If the Partial Structural Display is set to 'Core of Load-bearing Elements Only' the opening contours are not displayed correctly. As a workaround, please set the PSD to 'Core only' in combination with possibly putting the non-load-bearing elements on hidden layers. If this is not an option, contours can be drawn on 3d documents.
best, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
Ruben V
Thank you for the answer and workaround!
(òÓ,)_\,,/
www.studiov2.be
BIMcollab ZOOM
>>> Read my book!<<<
