Wall fill not printing
I'm using Archicad 24 Solo, having recently upgraded from 20 Solo (a big jump, I realize). For some reason, wall fills aren't showing up when printing a layout sheet.
Hello. did you click print in "black and white" on your printer settings? Personally I use that sometimes in case I need just a draft print.
Can you post screenshots of how it looks on the Layout, and possibly an image of how the printed result looks? You could also print it to PDF and post that.
