Wall with multiple windows / no lines between windows
I have to keep the 3 windows
I don't want to add 2D hatch
I have to keep "symbolic view" for my 3 windows
I have this :
I want this :
Without hatch like this :
I think it's a wall parameter. Any idea ?
Christophe - FRANCE
Formateur Archicad indƩpendant Ơ NANTES
Archicad 15 to 29 FRA FULL
Try the window 'ganging' options.
The windows on the edges will only need one side turned on.
Guru
Does not the Ganging option do that?
Ling.
Thanks Barry
Thanks Ling
Your reactivity is great !
Like usual with Archicad, the solution is easier as I guess !
I never need it before so I've forgotten this function.
One more time Thanks Barry & Ling
Christophe - FRANCE
