2017-03-13
09:32 AM
- last edited on
2023-05-19
10:10 PM
by
Gordana Radonic
2017-03-13 08:23 PM
gapy100 wrote:It would be helpful to see some screenshots of what you are describing, because I don't really understand the meaning of "colored black all over" or what you are trying to do with the dimension markers. It would also be helpful to add your ArchiCAD version to your signature.
Hello,
i would kindly ask you for some help. I have a problem when using waterproof material inside my composites. Inside archicad i see the "dashed line" as it should be, but when exporting the drawing in "hairline" to *.pdf in scale 1:20 its colored black all over. Any tips how to solve that problem?
Second problem i have is locking and rotating height dimension markers (putting foundations sections to foundations floor plan). Somehow i cannot figure it out how to lock the height so it would not change and rotate them regarding to correct position (they keep the original "horizontal" alignment).
I would kindly appreciate any information solving that problems. With kind regards, Gašper
2017-03-14 07:22 AM
2017-03-14 02:19 PM
2017-03-15 02:38 AM
gapy100 wrote:I would be guessing that the scale you are viewing in Archicad is different to the scale of the view you are publishing as a PDF.
