What happened to the 'Get page setting from Plotter' command
alexliz24
This is a command I frequently used. In the Plot Setup dialog, if you wanted to setup the paper size/roll length & width etc., you could also just go to the top of the drop-down menu, and there two commands:
Get settings from Printer
Get settings from Plotter
But today, I checked in ArchiCAD 11, then ArchiCAD 10 (both on Mac), then ArchiCAD 10 on Win, nada!
Am I just going paranoid? Or is the command right there before my eyes and I just need to get better sleep?
Thanks, people.
Alex Zachopoulos
MacBook Pro 17" 2.4GHz, MacOS X 10.5.6, ArchiCAD 11 & 12, WinXP, Vista (well, not really Vista...)
Chazz
Look under the Master Layout Settings. It's there for me in AC11.
Nattering nabob of negativism
alexliz24
Thanks, Chazz!
Mind got stuck (again)...
Alex Zachopoulos
