2010-10-11
09:36 PM
2023-05-19
10:16 PM
Gordana Radonic
2010-10-13 08:02 PM
2010-10-14 03:09 PM
2010-10-14 07:20 PM
David wrote:Thanks, David. I've updated the PDF below to mention Titles, changed some wording a little, and added another row at the bottom: offhand, I cannot see much of a reason to use the Figure Tool other than for separate x/y scaling, or PDF background transparency (when the PDF-to-bitmap conversion by the Figure Tool yields enough pixels that one doesn't have to use Photoshop/etc to obtain a higher resolution image).
This looks great. You could add that only Drawings have Titles (and so are best for Layouts). A few examples of when using one over the other would also be helpful (similar to your example: bringing in a scanned site plan that needs separate adjustments on the X and Y axis). In some cases there may be little reason to choose one over the other.
2010-10-14 10:00 PM
2010-10-14 10:16 PM
2010-10-15 01:37 AM
2010-10-15 03:07 AM
2010-10-15 03:13 PM
2010-10-15 06:37 PM
2010-10-15 07:00 PM
David wrote:Good catches, David! Thanks!
You could add that the Drawing Tool has the option of adding a frame to the image and can be cropped. I'm running out of ideas, you might want to move the "Practical advantage over other tool?" row to the top, as this is the short version for the comparison. Good work!
