Gus
What size fonts do you use?
I'm curious what size text people use for different types of information while creating construction documents in ArchiCAD?
What Size Text (how many points) do you use for the following:
Notes?
Dimensions?
Labels?
Room Names?
Any others?
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W [email protected]
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
9 Replies 9
I use the following:
Notes- 7
Dimensions - 9 ( I use superscript fractions so 9 is large enough to read them
Labels - 7
Room Names - 12
Drawing Title Names - 16
Drawing Scale - 8
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
In our office we usually use a 2.0 mm text size for Dimensions, Zone Stamps, Labels, etc. in Construction Documents.
It also depends on how much space we have in the rooms, sometime we can go up to 2.5 mm. But there were times when we had to go down to 1.8 or even 1.5 mm because the rooms were so small and we had to cram like 4 rows of text into a Zone Stamp.
But below 2.0 mm it gets hard to read when it is printed and photocopied.
For things that have more space like notes, schedules and stuff, it can be more: 2.5-3 mm, which is usually very readable.
Stephen Dolbee
Notes- 7 (5 if limited space)
Dimensions - 7
Room Names - 10
Drawing Title Names - 14 bold
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
Just so we can compare apples to bananas:
1 inch = 25.4 mm = 72 points.
1.5 mm = 4.25 pt
1.8 mm = 5.10 pt
2.0 mm = 5.67 pt
2.5 mm = 7.09 pt
3.0 mm = 8.50 pt
David Maudlin
My default font size for all but room names is 8 pt (default font is Hevetica, all caps), but can go down to 6 pt for small amounts of text when necessary. Room names at 10 pt. I expect some drawings will get printed at 1/2 size, making the font size 4 pt, which is a minimum readable size. If paper actually disappears one day and everything is on screen, then I will reconsider.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
1.5mm for all notes, labels and dims
2.0mm for room names/zone stamps
We mostly use A3 and A2 layouts, and find that both of these printed at A3 with this text size is ok.
If we use A1 with these text sizes, and print at A3 it is harder to read the text, but still possible to read.
DGSketcher
Legend
The pressure point is notes & dimensions. Ideally I use 2.5mm as a minimum which can be read (with my glasses) on a half size print, but I am drifting towards 2mm as a generally more useable size and my local builder is quite happy. I have used 1.5mm for door labels on a 1:100 scale fire plan to squeeze everything in and keep features visible.
Erwin Edel
1,5 and 3 mm for 1:100 plans.
2 mm and 4 mm for pretty much everything else.
I've noticed that 2 mm text is problematic with dimensioning and zone stamps on 1:100.
We actually use a simple trick, where we make a 1:75 scale viewset and rescale the placed drawings to 1:100 to make the 2 mm texts 1,5 mm.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
anatopu
Hello, is there any standards about this topic?
