White Background for Fills
Hello, I am having an issue with my fills. I want my stacked stone fill to have a white background instead of a grayish background. However, I do not see an option to change this in its setting. I am using a surface on a wall that has the stacked stone fill as its hatch. What should I do to fix this. Attached is a photo of a wall with the stacked stone surface. I have also attached photos of the settings for the stacked stone fill as well as the settings for the surface I am using with the stacked stone hatch. Thanks for your help.
Dave Seabury
Stephen
open your elevation or section marker and look under model display
and see if the surface pen is something other then white.
Just a thought
David
AC 19-26 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
Eduardo Rolon
In AC when you place a Fill or line with the same color as the background it changes it so that you can see it. It will print correctly. Check under Options-> Work Env -> On Screen Opt-> Automatically Pen Color Visibility…
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
