Why can't I see the bow under the Slab?
LeeJaeYoung
Why didn't I see it?
After applying this, I could see the bottom of the slab. What did I do wrong?
AC27 on window 11
Jeff Thompson
Looks like your slab has the cover fill turned on.  Highlight the slab and select the slab selection settings.  Under the Floor Plan and Section group look to see if the Cover Fill is checked.  Chances are it's checked and the background fill is either (91) White or is using (-1) Window Background color.
Project Manager
Rutledge Maul Architects, PS Inc., Seattle, WA
Windows 11 Pro, HP Pavilion Gaming Desktop 790, Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz 3.19 GHz, 32.0 GB RAM, 64-bit operating system.
Archicad 28 - Graphisoft Forward
Jeff Thompson
Project Manager
Thank you. I think I used pen number -1 when I was testing.
AC27 on window 11
Setup info provided by author
