Window Markers in Elevation
KOAN
Hi All,
I have a quick question... I'm trying to get my window markers in elevation to show as the marker that I've set for the window (W Marker USA 27).  I select all the windows in the elevation that I'm working on, go to Document > Label Selected Elements, but it doesn't place the marker associated with the window, just whatever the Label tool was last set to.
W Marker USA 27 doesn't appear to be an available marker to use with the Label tool so I can't set it manually... I feel like I've done this before without any issue so I'm not sure what I've messed up here...
Thanks for any advice!  I feel like I'm just missing something that should be obvious.
AC 26 USA
MAC OS 12.6.7 | R9 M390 2GB | 4Ghz Intel Core i7 | 32GB RAM
1 REPLY 1
The Windows Marker and a Label use different Library Parts and they are not interchangeable.
You will have to use a Label to label the Windows in an Elevation.
You can draw your Window Marker geometry using Lines and Autotext Text Block, and save them as a Label. Then you can use that to label the Windows in an Elevation.
