‎2017-04-21
01:56 AM
‎2023-05-30
10:00 AM
Rubia Torres
‎2017-04-21 06:11 AM
‎2017-04-21 08:37 AM
Stress wrote:Hi buddy, yeah you are right, it is the opening lines, but without them the elevations are going to be a problem, how are you working around this?
Pretty sure those are in the "Opening Lines"
settings of the window. You can turn them off,
but then they won't appear in elevation.
‎2017-04-21 08:45 AM
‎2017-04-21 09:31 AM
Barry wrote:Hi Barry, I think it does make sense to give them a thin pen and blend because opening lines really dont need to be thicker than cutlines anyways.
I think all you can do is to make them a thinner pen so they blend into the frame lines rather than being thicker than them.
‎2017-04-21 01:37 PM
‎2017-04-22 07:38 AM
David wrote:Hi David, I do have those settings in your highlight. If I uncheck opening line it takes away the opening line on the elevation view as well. And if it is checked it will appear in my section (I have set my section settings to show limited depth).
thinky0099:
Check to see if the opening line visibility can be controlled via Model View Options (MVO), they can in the US library. You can attach different MVO settings to different Views, so for the elevations they would be on and for sections off.
‎2017-04-22 03:19 PM
