I have always had problems with the Zone Stamps after upgrading to the newest AC version. I start by importing (and/or adding) my custom zone categories in my template. I normally have to also pick a new zone stamp (as the new versions tend to drop the older ones). I then customize the zone stamp parameters (e.g., uncheck frame, turn off finishes, etc.) for each of the new categories.
I think I'm all set, and then I go to test it by placing a new zone, but the default zone stamp parameters show up, completely ignoring my category level parameter edits. My workaround is to edit the placed zone, save it as a favorite, then use the favorite from that time on. Of course, this means a favorite for each of my zone categories. Another way, at the project level (during deadlines) is to globally select the placed zones and edit the parameters of the selection set, but that is also extra work.
I'd appreciate a pure solution as the logic of the zone categories immunity to cascading custom parameters escapes me.
BTW, AC 21 zone stamps are really a great improvement! So much more versatile. I do wish the parameters were view dependent, but I'm thinking the new scaling feature may be somewhat useful in that way,
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC27 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sonoma OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
