Zone not showing color, but my Graphic Override says it should
4hotshoes
I want to see the Zone for each room. I have a GO for zones to be the zone color and one for no color. It is not changing and I do not know what else might effect it. I have the Trace and Reference is off. I tried all my Renovation filters. Is this a AC23 glitch?
(Because: Have also been having trouble with an elevation not updating on the screen when I change Model View Settings until I go to the Layout sheet.)
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
4hotshoes
Sorry, I said the Trace Reference was not on, but it was. getting tired I guess. It is working fine. Too many variables to watch.
Todd Oeftger
DGSketcher
Legend
Are you using the default zone display rules within the GO? I just did a quick test on my Mac and everything appears to be working ok. Is there a possible conflict with other rules in the GO and have you taken into consideration the running order for applying the rules?
4hotshoes
Todd Oeftger
