Tuesday - last edited Wednesday by Barry Kelly
I want to sum areas by house numbers.
I have made two scedules (see the image):
In AC26 the scedule is correct. I can see all houses and their areas (the areas are merged items).
In AC27 the scedule is incorrect. I have houses H0, H1, H2 and H3 but the scedule only shows H0.
I quess the problem is with zone library part parameters, but why?
I have had the problem in AC26 too. It's random.
Solved! Go to Solution.
Tuesday - last edited Tuesday
What are your merge settings in the column headers? Maybe these are off.
You can change them by enabling "Merge Items" and then click in a column header in the schedule and then on the merge icon that appears in the column header (nr. 2 in the screenshot).
I think you'd need "Unique Values" & "Uniform Values" for the "House Number" column and "Any Values" & "Sum of Values" for your "Volume" column.
For a detailed description check this article by GS.
Let us know if that fixes it or if the issue persists.
Bernd
Same problem with different schedules where I use house numbers:
Bernd
Wednesday
Yes, this solved the problem. Thank you!
I didn't know there are these buttons in the header row.
