Zones: fills will not show up for zone stamps - AC-11
I am new to AC 11 (AC 9 previously) and cannot get the fills to show up on the zone stamps. The two places that I have tought to look are listed below.
Info Box/Settings Dialog Box/(fill is checked)
Navigator - View Set/Settings Dailog Box/Cd Hairline-VectHairline (or any of the other six options)
The wonderful AC 11 training manual (hehe) Shows that I should go to "Document/Set Model View/Model view Options". However I do not have a docuent tab, or at least cannot find it. Any assistance with this issue would be greatly appreciated.
Thanks,
Josh
3 Replies 3
rocorona
Can you find a "Document" menu in your work environment? The model view window should be there, with an option to hide/show the zone color/fill pattern.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
Yes, you have probably imported your AC 9 Work Environment into AC 11. All Documentations suppose you are using the Default Work Environment settings.
Great, thank you both for your time and advice! I had imported my AC 9 work environment and once I set AC 11 to the defalt AC 11 work environment I was able to see a document tab and fix the fill option.
Thanks again,
