2009-02-05
06:44 PM
- last edited on
2023-05-26
12:19 PM
by
Rubia Torres
2009-02-05 11:13 PM
manual (hehe) Shows that I should go to "Document/Set Model View/Model view Options". However I do not have a docuent tab, or at least cannot find itCan you find a "Document" menu in your work environment? The model view window should be there, with an option to hide/show the zone color/fill pattern.
2009-02-06 12:06 PM
rocorona wrote:Yes, you have probably imported your AC 9 Work Environment into AC 11. All Documentations suppose you are using the Default Work Environment settings.manual (hehe) Shows that I should go to "Document/Set Model View/Model view Options". However I do not have a docuent tab, or at least cannot find itCan you find a "Document" menu in your work environment? The model view window should be there, with an option to hide/show the zone color/fill pattern.
2009-02-06 04:14 PM
