heathldesign
angle dimension arrow markers point in same direction on layouts
why do the arrow markers in the angle dimensions point in the same direction in layouts but not in views? see pics
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.3. AC 27, 6000 USA
6 Replies 6
Weird phenomenon.
Can you try to decrease the size of the markers and see if that makes any difference?
heathldesign
Hi Laszlo,
no change. reduced them down to 1mm
Is your model by any chance far from the Project Origin?
In the past, users have encountered issues where the content of Drawings on Layouts does not correspond to what they see in the Drawing's source View. Modeling near the Project Origin fixes those types of issues.
heathldesign
They are away from the origin. Ill play with it when i get back from holiday.
heathldesign
Hi Lazzlo,
I played with it and moved the truss close to the origin and placed a new angle dimension with the same result on the layout.
I suggest that you report this issue to your local reseller.
One last question: if you place such an Angle Dimension in a brand new Project (New & Reset, Archicad default Template), is it displayed correctly? Also, if you copy-paste the Angle Dimension into this brand new Project, is it displayed correctly?
I am trying to figure out if the issue is file-specific or it happens in even new Projects.
