ā2003-12-02
04:33 PM
ā2023-05-30
10:10 AM
Rubia Torres
ā2003-12-02 05:06 PM
Ben wrote:AFAIK, you can only get information from construction element, not from object (you still can get generic info from it, such as X,Y,Z position, A, B, ZZYZX size, etc), but you won't be able to get directly specific object parameter...
Or label a steel section and have the label contain the section size and weight.
ā2003-12-02 05:14 PM
ā2003-12-02 05:27 PM
Ben wrote:You'll find a label attached here : it only works for slabs, but you should be able to adapt it for a beam or an object.
yes thank you anything will help, maybe using GDL but it cant script!! just basic cut and paste
Is there is a label tool out there that can return this information.
Will your custom label return the length of a beam??
thanks
Ben
ā2003-12-02 05:35 PM
ā2003-12-02 05:37 PM
Ben wrote:Let's hope so ! If any help needed fruthermore, contact me in PM
I shall try and adapt it, it works great for slabs I am sure it will be easy to get it to recognize beams
ā2003-12-03 04:33 AM
ā2007-02-28 07:02 PM
ā2007-02-28 07:41 PM
ā2007-02-28 07:50 PM
