2004-02-08
10:20 AM
- last edited on
2023-05-26
02:39 AM
by
Gordana Radonic
2004-02-08 07:24 PM
lsid wrote:... which means that you set one page per layout. Judging by your screenshot, you don't need more if it is only plans. Now either you will create a new layout for each sheet, or, if you want everything in one layout, then ...
i have set my page setup to 11 x 17 paper size using my hp 1220c printer and in the layout setup, i set to current paper.
lsid wrote:... set the layout size to the size all of your project sheets would be when tiled together - see my example; layout size on the top left, page setup top right.
so, what did i miss out?
p.s- i still can't get that multiple layouts as djorde did in previous reply.....?????
2004-02-09 01:11 AM
2004-02-09 06:13 AM
lsid wrote:Yes, it is; the offset one just shows the active sheet. Check on my example - the lower left corner sheet has the offset border, the orhers don't.
so, djorde, is this a normal scenario, having 2 red borders, offsetting each other even though the layout and page setup are the same?
2004-02-09 06:27 AM
2004-02-09 06:32 AM
2004-02-09 07:54 AM
lsid wrote:Instead of hitting the Post Reply button, hit the Quote button in the top right corner of the post.
btw, how do i do what you did - a quote with a border as shown below?
2004-02-09 07:57 AM
2004-02-09 12:48 PM
lsid wrote:Good
i think i understand your explanation of selection bigger paper size to fit in the drawing sheets.
lsid wrote:As you should be getting 8.1 (it is a free upgrade from 8.0 to 8.1 AFAIK) believe me it is worth it. 7 is still perfectly capable of performing, but 8.x is taking the whole story into the new chapter.
i am still waiting for gscne to reply my email for an upgrade from 7 to 8.0 and then decide if it is worth upgrading.
