Service alert: BIMcloud SaaS disruption in the US Read more
building material trimming problem
alex reznick
Tell me what I'm doing wrong, I checked the priorities of the materials everything is in order and the insulation will climb on the masonry anyway, helpСнимок экрана 2022-02-10 092435.jpg
The stronger material will cut the weaker material, which is exactly how you have it set up.
You actually need to make the yellow in my image stronger than the purple.
for some reason, changing the anchor line relative to the side of the wall corrects this error, but I don't think this is a solution, since I need a binding in a certain place
