SOLVED!
can I copy dimensions II ?
LeeJaeYoung
can I copy dimensions?
can I copy dimensions? - Graphisoft Community
I connected the grid to the dimensions of the basement 2nd floor, and I want to copy the dimensions to the basement 1st floor. However, it is not copied. Is it the same method as explained in the link below?
ArchiCAD does not understand dimensions.
If there is a hotspot at the location where you copy and link, it seems like you can create the dimensions by programming it....
Is there a reason why you do not do it in Graphisoft?
I want to know about the dimensions pursued by Graphisoft.
AC27 on window 11
11 REPLIES 11
Ah! You said there isn't.
I made a suggestion. But it didn't work.
That's why I had a question.
1. In AutoCAD,
If you draw line 1 in the API, a dimension with an association is created at the end point closest to the intersection point among the two endpoints of the intersecting LINE.
2. In AutoCAD,
If you copy a dim without an association and automatically connect it in the API, it is transformed into a dimension with an association.
There seems to be no reason why it doesn't work in the program, so I'm curious why it isn't provided, so I'm asking this question.
At first, I thought it was a consideration that Archicad dimensions don't move from architecture to structure, but now I think it can't be done.
If it doesn't work after making a wish for so long, then it means that graphicsoft is just like autodesk in that it doesn't communicate well.
Thank you. Okay, that's it.
AC27 on window 11
the proposal involves eliminating current "click-based" method. instead, the tool would "read" the model (exactly like the section tool), and generate dimensions according to the model and set criteria.  This way your only work would be to place the tool where you need the dimensions, which would always stay accurate, no matter how many edits You make to the model.
Setup info provided by author
