can't create a custom CUT FILL
cocoloco
Hi! I tried to create new fill but what I need it to be is also a "cut fill". it does not let me do it and this is exactly why I needed to create a custom fill. it does not say why I can't save it as cut fill.... also no matter what my setting is, the line showing in the middle won't dissapear and it shows like that even when using as a standard fill (not cut fill). I don't want to show any lines/fill separators in my fills, could I delete it?
please help?
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
AllanP
Image fills can only be used as Drafting fills or cover fills, not cut fills
https://helpcenter.graphisoft.com/user-guide/128564/
I have been using ArchiCAD continually since ArchiCAD 4.5, 4.5.5, 5, 5.1, 6, 6.5, 7, 8, 8.1, 9, 10, 11, 12, 13, 15, 18, 21, 22, 25, now testing 28
Member of Architalk since 2003, but missed the migration to Graphisoft.
AllanP
Whyyyyyyyyyyyy!!😩😩😩
would you know how to remove the line when the pattern repeats? It shows in floor plan . I’m ok the patterns repeats but don’t like when line shows in the middle of it when it’s not needed
It looks like an issue with the original Image.
you will need to fix that to get rid of the line.
i do not get lines when i make image fills.
