ceiling slab, has repositioned itself, will not drag
A19, Microsoft Windows 7 x64
I am unable to drag ceiling slab to correct location.
I am also not able to drag a text to correct position.
It seems that grid lock is on, but I have not used it.
Any ideas?
3 Replies 3
The snap to grid was on and once it was off, I was able to click and drag.
What I do not understand is how did grid snap get set on?
It seems that if you pass over control, it could set on without you realizing this has happened?
Erwin Edel
hotkey is S, you probably accidentally pressed that.
Happens in our office every other month
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Eduardo Rolon
and that is why it is one of the first shortcuts that I remove in my W/E settings.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
