2013-10-02
10:30 AM
2023-05-26
12:18 PM
Rubia Torres
2013-10-02 11:39 AM
2013-10-02 11:55 AM
2013-10-02 01:03 PM
2013-10-02 03:03 PM
2013-10-03 10:26 AM
2013-10-03 11:26 AM
laszlonagy wrote:YES!
You should create a wish for this.
Actually, I think this could be implemented as a new option in the Model View Options Dialog. It could be call "Show Structure Outlines Only" or something like that.
It could be a useful feature addition.
2013-10-04 09:07 AM
2013-10-04 09:19 AM
alemanda wrote:and the problem is also the concept of "overriding". In fact actually AC overrides at the end of the generation of the plan view ... but it should override before generating the plan view (if I'm not worong AC 17 does it in this way in the sections' generations with override option enabled). In that case all the cut fills would be the same and the junctions would clean automatically (even with the existing code) ... it would be enough pass the "cutfill parameter" equal for all the elements before generation of the plan view ... in words it seems very simple to implement ... Reality is much more complicated for sure ...
David,
.. The problem is how AC generates the cutlines and skinseparator lines...
2013-10-11 09:16 AM
