alemanda
clean architectural plans using composites
Hi to all,
I'd like to use the composites to have a more detailed plan.
At the same time, using the live model, I'd like to be able to switch from a very detailed plan to a very simple clean architectural plan.
I tried to to some test playing with model view options but I didn't get the expected result. In fact, even overriding the cut fills and turning off the skin separator lines, the result presents still skin separator lines.
Look at the attached pdf file.
Any (automatic) workaround?
Is it a bug? It seems that the code to write the GDL for 2D plan is incomplete (it does the job partially).
I tried the demo of AC17 but it is the same.
Thanks
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
13 Replies 13
Mario Sacco
alemanda wrote:
Nobody has my need to produce clean architectural plans using the composites?
Yes, I have the same problem.
I need to create two different documents pln to create an administrative drawing and working drawing. It's a lost of great amount of time.
It could be an option like: "Override composite wall setting for a scale above 50, otherwise override the basic wall setting". I mean contour pen, background pen, fill pen, fill symbol. In fact every wall already have different setting for composite and basic wall. You can switch from the different setting with a simple override in model view option.
It's could be really a very great enhancement.
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
Eduardo Rolon
Meanwhile my work around has been to use three specific pens for the "interior" of the composite and control that thru Pen Sets, making then "White", "Gray" or "Black" as necessary based on scale of drawing or information.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
alemanda
@ejrolon
This is a good workaround.
I think that the option already implemented should work as we expect overriding everything ... Simply it doesn't work as it should ...
Hope they fix it even for ac16
AC27 latest hotfix
Win 11 Pro 64bit
If you find this thread and wish to vote, Alemanda's wish for this simplified model view option ('Show structure outlines only') is here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=43820
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
