dimension text problem
In my linear dimension the text appears with a comma - like: "1,000".
I work in centimeters and when the dimension is from 000 to 999 it is ok.
But when it is more then 999 the dimension appears with comma - 1,000 - which means 10 meters
I know that the dimension text can be edited. But this means that I have to edit every dimension line by hand.
Is there any other way to remove the comma (automatic)
5 Replies 5
Link
Wow - losts of posts about the same problem mate. Our good moderator Djordje may have to clean up a bit now, but I guess while he's at it he can implement that feature he's been thinking about for so long, where it forces new users to include hardware/software specs in their signtaure.
As you can imagine it's a little difficult to give you an accurate answer without knowing this information. On a PC I think it has to do with your Regional and Language Options, accessed via the Control Panel.
Who knows Djordje may also write a little blurb on using the Search function too!
A quick search will return results like this or this or even this!
Good luck!
Link.
Erika Epstein
Link.
So much for Djordje's weekend
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Djordje
Change the thousands separator in your Windows settings.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje
Well ...
My weekend is Friday, as you probably don't know 😉
And deleting is not so horrible ...
Djordje
HP Omen
