dimensioning disappears on layout
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2009-06-17
11:49 AM
2023-05-23
12:01 AM
Gordana Radonic
I am using a German version of archicad 12 and have problems with he dimensioning. I will try to translate specific terms from archicad, but I am not sure wether they 're correct.
I used the dimensioning-tool (Bemaßungswerkzeug) in my floorplans in the "drawing" or "model" window (Zeichnung). Then I placed my drawing onto a layout using the "save section and place on layout"-tool (ausschnit sichern und auf layout platzieren) by clicking right on "first floor" (EG) in the navigator and choosing the tool from the drop down list. the layout-window opened and I placed my drawing. But the dimensioning wasn't showing.
So I also tried it with drag and drop in the organizer (Organisator), but nothing changed.
All layers are opened and unlocked. I can't find any setting possibility in the drawing-settings. I also tried different modi in the quick-settings, such as "execution planning" (Ausführungsplanung) instead of "individual".
Direct printing from the drawing window works, but this is not the way it should be, isn't it?
What also confuses me is that two friends of mine using the same version as I do, have completely different experiences with this topic.
For one everything works correct and the dimensioning doesn't disappear, no matter what way she puts it on "layout".
For the other one the dimensioning also vanishes when she uses "save section and place on layout" but does not when she uses drag and drop within the organizer.
I thought I probably overlooked something, but how then can archicad 12 work in such a different way as the examples of my friends show?
Thank you for reading and helping me.
Please tell me if you need more information.
best wishes
apfel
- Labels:
Dimension Tools
Layouts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-17 07:05 PM
You must first save a VIEW with the correct layer combination (scale, MVO etc.) that will include the layer the dimensions are on.
Then the view/drawing you place on the layout will have the information you want.
HTH
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-17 11:09 PM
I am not quite sure if I followed your instructions correctly as I might have misunderstood the walkthrough.
That's what I did: in the drawing window, right click on first floor in navigator, dropdown opened, click on "save section" (ausschnitt sichern), then click on "save section and place on layout" in the same drop down. The window changed to layout and I placed my section. And again no dimensioning was to see.
Of course I checked again that all layers were unlocked and visible.
Please tell me if I made a mistake following your instruction.
Best wishes
apfel
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-17 11:18 PM
I just tried wether the problem exists in new data as well.
It doesn't. It is only not working in my topical project. They both do have the same template.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-17 11:37 PM
1. You need to create a VIEW in the VIEW MAP saving it with the appropriate Layer Combination, model view option (MVO), dimension profile etc. as shown at the bottom of the VIEW MAP.
2. Place by dragging and dropping this VIEW onto a Layout sheet.
If you create the drawing on the layout sheet directly from the PROJECT VIEW (Orange Symbols) then the drawing will not be saved with a specific Layer combination.
See the CREATE VIEW section in the archicad help in the file menu.
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-18 09:46 AM
I followed your instruction, but I couldn't find anything about layer settings in the framed area.
Anyway in the placed view on layout now not only the dimensioning is missing, also various walls, doors, windows and claddings.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-18 02:51 PM
Dimensions can be associated with either the core, finish, or the entire structure depending on what was turned on at the time the dimension was placed. If the finish is turned off, any dimension associated with it will turn off also.
I'm guessing you may have the finishes turned off in the view, but not on the floorplan.
Hope that helps!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-18 07:40 PM
Thank you very much!
Although I have no idea when I had changed this settings (I never even looked at them before), but it worked.
Also the other way (save view and place on layout) works again.
Thanks again as well to Erika.
yours
apfel
