SOLVED!
dimensioning : walls vs. nodes
Dave Brach
when I start the dimension tool, I can click on multiple nodes before double clicking and using the hammer to place the dimension string. But when the first thing I click on is a Wall, then it automatically places the string immediately. I want to be able to click on a wall as the first click and continue to click on walls and nodes before placing the dimension. Help?
Dave Brach/architect
AC26 MBP OS Ventura
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
1 ACCEPTED SOLUTION
Solution
Stress Co_
Is "Geometry Method: Single-Click Thickness" on?
https://archicad-talk.graphisoft.com/viewtopic.php?f=11&t=62101&p=285560
Marc Corney, Architect
Red Canoe Architecture, P. A.
2 REPLIES 2
Solution
Stress Co_
Dave Brach
Marc, thank you. The thing that tripped me up is that I was searching, searching the Dimension Default Settings box, and not the Info Box. I always thought they contained the same information, but apparently there are addtional settings in the Info box...
AC26 MBP OS Ventura
