ā2010-05-18
07:22 AM
ā2023-05-30
10:06 AM
Rubia Torres
ā2010-05-18 07:59 AM
Llian wrote:Make sure you use the "Gravity to mesh" button when placing your spot levels.
1. level dimensions are showing as 0.00 for all my contour points. i've set z height to 1'-0 and sections shows contours slope of 1'-0".
Llian wrote:The mesh tool has 3 options - surface only (they call it superficies), surface with skirt or solid body.
2. i've used sea level and the mesh plane is set to 122.76' from sea level so the section is fairly thick. how do i adjust the view so the 3d is now showing the thick earth?
ā2010-05-18 08:02 AM
ā2010-05-18 09:45 AM
Llian wrote:No you can just select the mesh and change the option in the propeties dialogue.
thanks....so for answer [1]..do i need to redo the mesh ?
