‎2007-12-17
09:15 PM
‎2023-05-30
03:20 PM
Rubia Torres
‎2007-12-17 09:32 PM
‎2007-12-17 10:30 PM
npacella wrote:that sounds a bit confused to me. if you are laying out to finished face (bad practice!) of your wall you shouldn't be dimensioning to core only anyway? but since your dimensions are displaying the outer extents of the composite, this is in fact what you need isn't it?
I haven't tried this before today but I am seeing more contractors that are not laying out to face of finish wall as we direct.
I selected 'dimension to core of composite walls' in the dimension tool, I using a composite wall with the interior framing designated as the core but it only dimensions to the exterior of the composite wall.
‎2007-12-17 10:51 PM
‎2007-12-17 10:53 PM
Cary wrote:Cary, I did that and it only allows me to dimension to one side of the core unless you can specify two reference line offsets.
if you choose either the left or right "construction" method you can off set the walls reference line by the the thickness of the finish materials thus moving the refeerence line to the face of the core material.
FWIW...contractors do "better" measuring to/from the face of the core.
‎2007-12-17 11:03 PM
npacella wrote:the reference lineCary wrote:Cary, I did that and it only allows me to dimension to one side of the core unless you can specify two reference line offsets.
‎2007-12-17 11:06 PM
‎2007-12-18 12:32 AM
‎2007-12-18 06:05 PM
‎2007-12-18 09:53 PM
